Why run NATPA when USAP is better anyway?
J. D . owner
09-10-2002 16:13:24
you guys dont see all the crying over all the small stuff from the USAP guys. why do you stay with a club that clearly has major problems. I go to lots of usap pulls and have a great time even when I dont finish well because of the good sportsmanship I see there. I went to one natpa pull and dont care to even go watch one let alone pull at one again. NATPA is doomed to fall if major changes are not made soon.
JD Owner Too
09-12-2002 03:46:06
 Re: why run NATPA when USAP is better anyway? in reply to J. D . owner, 09-10-2002 16:13:24
Are homemade heads,such as Bears legal with USAP? Can you switch to a later model block that is a different size than the original?
open class puller
09-10-2002 19:06:04
Unfortunately the USAP has speed limits and all the strong div 4 & 5 tractors pull NATPA w/o speed limits. There aren't too many tractors in the USAP 8 & 12 mph classes anyway.
Don
09-14-2002 03:23:54
 Re: Re: why run NATPA when USAP is better anyway? in reply to open class puller, 09-10-2002 19:06:04
That's because the strong div. 4/5 tractor owners throw more money on the track then skill!
Masseypuller
09-11-2002 16:06:14
Then tell us why the Div 4 or Div 5 tractors are not running the 12 MPH classes?
Even the Div 4 or 5 tractors aren't topping 12 MPH!
Even if they could run 12MPH, if there aren't that many tractors in that class wouldn't they be guaranteed to win it?
Jerry B
09-11-2002 07:05:30
Has anyone ever asked Lampkin about adding such a class as "unlimited" or "open" without a speed limit? I am sure if the membership grows well enough and the desire or need for such a class as this is felt strongly enough, then changes can be made to accomodate the "fast and furious" tractors.
Just my .02 cents worth.
BUCK
09-10-2002 20:26:51
That's OK it sounds like you have some real strong tractors in div. 4&5 NATPA .Just get your rules squared away before someone has a fatal heart attack.It does make for good post though.
