Tires new or old
mm puller
09-08-2002 16:50:21
i pull a oliver 60 with old tires runs pretty good but cant seem to get it to pull no matter what kind of track on other hand i pull with amm zb with new tires and it pulls pretty good tires are 13.6x38 2 sizes bigger than stock and oliver tires are the stock 9x32 and some oliver 60 i see do real good yours trully baffeled thanks peter
wastedtime
09-10-2002 19:34:21
 Re: tires new or old in reply to mm puller, 09-08-2002 16:50:21
Old tires are by far the best I've found. Find a set that has been road worn to a sharp edge. Next thing is tire pressure. A good rule of thumb is 1-1.5 psi per 1000 lbs. you are pulling i.e. 5000 lb class you would run about 5-7.5 psi. Give that a try and if it don't work I'm sure someone else will have some more advice for you.
