U motor and clutch
MM U future pul
09-06-2002 20:45:46
I plan on building a U for pulling. I want to do the work myself, and want to know how to get the most power. Do I go with the 800 setup..4229 heads, or do I go with the m5 setup with 4232 heads? What is best? and, WHere can I get a ceramic(spelling) clutch, or whatever is heavy enough to work? What about heavier gears? Are mine heavy enough? thanks for all reasponses,
A puller
Glenn
09-07-2002 14:05:07
 Re: U motor and clutch in reply to MM U future puller, 09-06-2002 20:45:46
Before you put money in any of that, check the rules where you will be pulling. National rules will not let you use 800 blocks or heads, USAP will. Find out first, not much good in building a tractor you can't pull. Glenn
cwj
09-07-2002 12:04:52
i have heard of some guy's saying that the blocks and heads will work off a g1000 on the u.how are you wanting to spend.
MM pulller
09-08-2002 09:50:11
 Re: Re: U motor and clutch in reply to cwj, 09-07-2002 12:04:52
I don't care how much, I just want to get the parts as cheap as possible for between 180 and 200 hp.
