Rims for 14.9X38 tires
Vic
09-06-2002 10:16:09
Hey guys,
In your opinion, is it better to pull with a larger rim (14-15 inch) for 14.9X38 tires, or would you stick with the standard 11 inch rim?
Thanks!
B puller
09-08-2002 17:33:18
 Re: Rims for 14.9X38 tires in reply to Vic, 09-06-2002 10:16:09
I have a B that I put pressed steel rims on last year. I found a set of 16" rims that had 18.4- 38 tires on them. On a 16" rim they look mean and have quite a foot print.
52 A Boy
09-06-2002 19:10:49
I have a 52 A JD and I pull in Tx and are tracks are not near as good as some of yalls, and im using stock rim (11 in.) and I cant get all the power to the ground in the 6600 div. and empty i way around 5300 pounds.
52 A Boy
Ted
09-06-2002 15:06:40
I just mounted a set of 14.9 Firestone F&R on 14" rims and they still crown some. 11" would have been way to narrow.
JDGnut
09-06-2002 13:25:48
The 14in rim sure makes the tire sit flatter on the ground, and looks better too.. the 11-12 in rim is just too narrow for the 14.9 rim. JDGnut
I'll send you a pic of our 70 with the 14.9's on 14 rims.
