Re: Pulling tips for a beginner
Red 'nOrange
09-04-2002 18:07:06
Not a pro by any means but have some experience with M pulling. Tire pressure 8-12lbs is where we run. Depends on track, tractor weight, and tires. In general, the harder the track, the higher the pressure. We have only pulled in low gear w/ 14.9 tires and usually run out of traction in 6000# class and out of power at 7000#. Start w/ 1/3 to 1/2 throttle and after clutch and tires have hooked up, open it up. Took 2nd behind a SMTA using the TA a couple weeks ago. Have fun!
