Tires for Pulling
Bleeding Orange
09-03-2002 18:04:59
I pull in local pulls with a WC Allis. Some tracks are hard surface, some are clay. What type of tires should I be looking for for each of these different kinds of tracks. The hard surface tracks are either cement or blacktop. Our local rules say I can't be wider than 13.6. Any suggestions would be greatly appreciated.
GREG
09-05-2002 19:25:25
 Re: Tires for Pulling in reply to Bleeding Orange, 09-03-2002 18:04:59
on a hard surface I use a set of turf tires. I have two set of tires depending on trac surface
GREG
09-05-2002 19:24:48
mike
09-04-2002 06:22:58
never seen a pull on conrete/blactop but have heard that you reverse your tires when pulling
super G
09-04-2002 20:16:19
 Re: Re: Tires for Pulling in reply to mike, 09-04-2002 06:22:58
Let me tell you. I have never really seen a diference.... your draw bar make a huge difference on pavement.
Ever tired spinning your tires backwards on black top with the tractor chained to something solid (fork lift) it puts a killer edge on them that is "road worn"
jeff
09-03-2002 19:28:35
Ya'll pull on asphalt and concrete?? That is interesting as I have never seen that. Could you semd me some pictures? ( I am really not trying to be a smarta** , I honestly have never heard of it )
Jack
09-03-2002 18:44:08
From what I have seen,Armstrong(now Titan)about half worn will do as good as anything out there.Good luck.
Pavement Puller
09-05-2002 12:55:37
 Re: Re: Tires for Pulling in reply to Jack, 09-03-2002 18:44:08
The best tire for pavement or concete is a set of uncutlongbar- shotbar firestones( The kind that are used for V-cuts) turned backwards. The more rubber you can put on the ground the better off you will be!! We have took an old pair of radials and cut all the tread off of them. They worked like a drag slick, then they outlawed them!!
JohnDeere2Cylinder
09-06-2002 13:28:30
 Re: Re: Re: Tires for Pulling in reply to Pavement Puller, 09-05-2002 12:55:37
Do you think that no tread at all (completely worn out tire) is better than a sharp edge in front of a mostly worn out tread? Interesting opinion. I notice that racing cars on blacktop or concrete use slicks, not mudders with sharp front edges. What do you think?
