Speed Limit Enforcement
Blu_Pete
09-03-2002 16:21:42
Looking for some response or opinions on this idea. In a speed limit class, anytime the puller exceeds the speed limit, his distance holds or doesn't accumulate any more until he's back to the speed limit. So anytime the horn blows your not adding to your distance. If you exceed the speed limit for 25 feet, your distance that is recorded as your pull will be 25 feet shorter than your actual distance. This might possibly be all done by the sled computer. Should put an end to the guys ignoring the horn. Tell me what you think. NICELY PLEASE !!!!! Just an idea.
ollie puller
09-03-2002 19:30:05
 Re: Speed Limit Enforcement in reply to Blu_Pete, 09-03-2002 16:21:42
I feel that i like it the way are club is the 3rd beep your out you get two beeps and the third on your dissqualified. and if the horn beeps constanly for more that 3 sec then you are also out.
D-17 Puller
09-03-2002 16:59:16
In our speed limit classes,if the horn blows after the 75 feet marker, you are disqualified. Division III in NATPA is that way. That would stop your speeders.
deere power
09-03-2002 20:09:29
 Re: Re: Speed Limit Enforcement in reply to D-17 Puller, 09-03-2002 16:59:16
around here you can blow it all you want until 100 feet...if you blow it past 100 feet, your footage is measured where it blew. if you keep going you're out.
