Jerrys g head
k d
09-02-2002 19:56:03
I have a jerrys head on my g will i run better yousing the plugs in the head or block.
lynn
09-03-2002 17:35:48
 Re: jerrys g head in reply to k d, 09-02-2002 19:56:03
k d..put one on a stroked g a few years ago..dyno showed 81 in the block..killed the tractor and changed plug wires..82 in the head..not enough differance to say they make more power..we use the ones in the block..easier to check and change..lynn
G Taylor
09-03-2002 19:15:01
 Re: Re: jerrys g head in reply to lynn, 09-03-2002 17:35:48
Using a mag, distributer or a MSD box?
lynn
09-04-2002 17:52:03
 Re: Re: Re: jerrys g head in reply to G Taylor, 09-03-2002 19:15:01
G Taylor..one of magneeders hot wico mags..lynn
G Taylor
09-04-2002 20:18:18
 Re: Re: Re: Re: jerrys g head in reply to lynn, 09-04-2002 17:52:03
I wonder if any dyno difference would show with one of those multiple spark MSD doxes that spark several times over 25 degrees crank rotation? Optimum timing advance would likely be different with plugs in the head vs block. With a msd box timing can be retarded a little to limit pinging without power loss.
lynn
09-05-2002 17:15:59
 Re: Re: Re: Re: Re: jerrys g head in reply to G Taylor, 09-04-2002 20:18:18
G Taylor..i don't think it would do anything but help..to what extent i would like to try one and find out..i always set the timing on the dyno at around 500 rpm on the pto so it should be optimized there..with the higher compression tractors i retard the governor one tooth so i can retard the timing..the mag won't retard enough to get maximum hp unless i do this..figure there is 18 to 20 btdc..need to check with a light but just haven't..lynn
