Pistons for WD45
Red 'n Orange
08-30-2002 19:44:50
OK Allis pullers, What is the best piston choice for a WD 45 being setup for Division II or III pulling? Want to retain the ability to bush hog with the tractor if desired. What works and what don't?
Rod Bolt
09-02-2002 19:50:50
 Re: Pistons for WD45 in reply to Red 'n Orange, 08-30-2002 19:44:50
Buy a set of arias pistons..... .make good HP. and dependable
GKB
08-30-2002 20:21:34
I JUST BUILT A WD45 AND FOUND A SET OF SOME TIPE OF HIGH ALTTITUDE POWER CRATER WD PISTON.IT GAVE ME ABOUT 270PSI.IF YOU WANT A GOOD PISTON FIND M&W PISTONS FOR WD/WC AND THAT SHOULD DO THE TRICK
BUCK
08-31-2002 21:26:34
 Re: Re: Pistons for WD45 in reply to GKB, 08-30-2002 20:21:34
DID you box the rods??? They won't take that very long.Believe me I know.
Red 'n Orange
08-31-2002 18:38:47
Thanks for the reply. That is high compresion. Are they 4 1/8" diameter and what octane gas do you have to run with this setup?
GKB
09-03-2002 18:38:23
 Re: Re: Re: Pistons for WD45 in reply to Red 'n Orange, 08-31-2002 18:38:47
it is 4 1/8 bore.and running 110 octane.I am thinking of selling this motor to go big.if anybody would be interested call 573=547=3539 between 5pm/9pm.I live in southeast missouri.not sure of HP.but put 15.5/38 tires on tractor and didnt have any problems with power 3500/4000/4500.in 3MPH farm class.
