K N Air Filter for JD G
JohnDeere2Cylinder
08-26-2002 11:48:26
Hello,
Where do I find a K & N Air FIlter for JD G, 2.75 inch intake, 5 inch diameter, 6.5 inches long, part no. F030E6?
Thanks
Gman
08-27-2002 19:26:40
 Re: K N Air Filter for JD G in reply to JohnDeere2Cylinder, 08-26-2002 11:48:26
JD 2 Cyl. I have a JD "G" Puller paper filter will not flow it,I learned the hard way fell on my face at a big pull. The wife's panty hose did though till I could come up with something better. Gman
Eric
08-26-2002 16:11:28
I would try summit racing 1-800-230-3030. One word of caution, I have seen first hand that a cone type filter that size is not large enough for even a G in mild tune. My brother has a G with .125 over M&W's and some head work and did not see one hp gain over his oil bath set up. When the tractor was running the filter actually was sucked in a bit on every intake stroke. I would suggest a larger round automotive type filter to do the job.
