WHAT MAKES A GOOD PULLIN TRACTOR
Hoosier Mark
08-24-2002 09:29:01
I WAS JUST CURIOUS WHAT MAKES A GOOD PULLER, A FARMALL "M" OR A OLIVER "77" OR "88"? AND CAN YOU EXPLAIN WHY IN EACH CASE? THANKS IN ADVANCE! HOOSIER MARK
ryan
08-25-2002 09:55:57
 Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to Hoosier Mark, 08-24-2002 09:29:01
oliver 88
johnny
09-05-2002 00:15:46
 Re: Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to ryan, 08-25-2002 09:55:57
I think its the color that makes a tractor pull good Red
johnny
09-05-2002 00:15:07
G-MAN
08-24-2002 09:48:43
Mark, nearly any tractor can be a good pulling tractor. Some do better in certain divisions and weight classes than others, for a variety of reasons. What it usually boils down to, though, is the guy in the seat. 90% of the time, the guy with the best track-reading, set-up and driving skills will take home the trophy. That's why you see 40 hp stock tractors beat 100 hp hot-rods from time to time. It isn't all about what's under the hood or what color paint is on that hood.
Farmall Boy
08-24-2002 12:04:13
 Re: Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to G-MAN, 08-24-2002 09:48:43
I agree with the G-Man pretty much. But with a 100
horse power you cold pull in second witch takes a
lil less skill I think. We hav an M with 281 cubic
inches(i kno not realy a whole lot) in 1 gear you
realy hav to use those breaks and throttle down,
but in 2 you hold the throttle back and ride it
till it dies(not realy good on the motor). We hav
2 m's that r always 1 and 2. One of them is stock
an the other is a 450 motor. Besides tactic G-man
good tires wouldn't hurt. If you think some of my
thoughts are wrong o well I'm only 14 and hav been
pullin 2 years. I LUV IT!!
real puller
08-24-2002 21:04:58
 Re: Re: Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to Farmall Boy, 08-24-2002 12:04:13
You have been pulling 2 years and that is 2 more than G-MAN,pay no mine.....
G-MAN
08-26-2002 05:55:47
 Re: Re: Re: Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to real puller, 08-24-2002 21:04:58
Actually, I pulled my first tractor 10 years ago. I pulled it for a couple years and then we began pulling four wheel drive pickups. I suggest you worry about something you know about, rather than making things up. And regardless of my experience, at least I have the guts to back up my opinions with an email address. Now go run and play, little boy.
G-MAN
08-24-2002 12:16:35
I don't think you're wrong at all. In fact, you brought up some good points that I failed to mention. Good tires are definitely important. Your comments about the bigger tractors pulling in higher gears is also correct. I guess the direction I was leaning was more toward the stock-type low-gear classes. Obviously a 40hp stocker isn't going to stand much of a chance in Division 5, but on the right track in low gear it may be able to put more horsepower to the ground than the 100 hp tractor - especially if the driver is one of those good ole boys that knows his tractor backwards and forwards. Good luck with your pulling. I wish I could have gotten started at 14. I'm 27 and I'm really not into pulling as much as I'd like to be, except for going to every pull I can and talking to as many pullers as I can. Maybe next year my "G" will be up and running. I'm sure I will be the one getting an education then - from the tractor and the other pullers.
Farmall Boy
08-24-2002 19:09:40
 Re: Re: Re: Re: WHAT MAKES A GOOD PULLIN TRACTOR in reply to G-MAN, 08-24-2002 12:16:35
Thanks for the complements but our second gear is
under our speed limit(4mph) but some places
antique speed limit is 3mph so you hav a good
point.I think i'm veryluky to be able to pull.And
even though its a john dere i wish u luck fixing
it .And not tryin to say your wrong cause we have
been beatin some tracors when we were in 1 gear.
Jus last weekend we beat a bored g and bored harr
parr (oliver) wich were both in 2 gear. (You know
their bored when then they pull 8600 in 2nd gear
and spin out). And i saw a b with that very slow
gear full pull(the only 1 in his class) so 1 is
better on those hard biteing classes. I'm not
sayin you were wrong cause slow is good for some
ppl(proved by the B) and i know you know what your
talking about.
