Please help puller. Tire pressure, and other tire questions
puller 4 life
08-16-2002 19:09:52
I have a pulling tractor that run out of traction every time. My tractor is stock
I have 14 pounds of air in my tires. The tires are 11.2-24 goodyears.If I let them down to 12 psi would it hurt? Is there any danger in letting my tires down that low? Will that probley slove my running out of traction problem? Because that is were I get beat is running out of traction.
Thaks again for your help
Agent Orange
08-18-2002 17:34:56
 Re: Please help puller. Tire pressure, and other tire questions in reply to puller 4 life, 08-16-2002 19:09:52
Good advice all the way round. I pull a stock AC WD and if the track is really hard I run around 3-4 if it's a good bighting track I go up from there. Keep good records (it will help). Sometimes you just have to guess!
Slo
08-17-2002 19:11:57
There are a lot of factors to consider with tire pressure. Rim width, sidewall strength, weight class, wheel weights, clay track, sand track, etc.
I run 13.5 lbs in a set of 15.5's on 14" rims, and get a nice hole in 5500 with 2 sets of wheel weights. Flat, no easily discernible dish or cup on a power track.
With the tires you describe, I'd start at 8 and work my way around. Run the air pressure that gets you a nice flat hole when you pull out of them. Use 1/2 lb adjustments to fine tune. Take notes at each pull to refer back to, it helps.
Doug in OR
08-17-2002 10:59:28
Try going way lower than that. Go to 8 psi. If that doesn't scare you when you pull, try 6 the next pull. Yes, it makes a *big* difference on my tractor.
carl
08-16-2002 20:27:19
I run 14 in the 6 and 18 in the 8 on my tires they are the same size i just have them on widend rims and they bight good!
John
08-16-2002 19:36:11
depends on the class, We run 10 lbs in the 5, and 12psi in the 6, 14psi in the 9
John
jimmy funk
08-17-2002 12:24:31
 Re: Re: Please help puller. Tire pressure, and other tire questions in reply to John, 08-16-2002 19:36:11
we run 1 1/2 pounds for every thousand pound of weight so say i am pulling 5000 7.5 pound hope this helps p.s pull farmall m and 560 and johndeere a and 70
PeteNY
08-17-2002 19:19:16
 Re: Re: Re: Please help puller. Tire pressure, and other tire questions in reply to jimmy funk, 08-17-2002 12:24:31
Hey Jimmy, How does the 70 pull? Is it gas? Ours is heading to her first NATPA pull tomorrow, she has done well in the local fair pulls, but the lack of rules there makes them no fun (we pull strictly Div. 1 with all of our tractors.) What classes do you pull it in? Thanks Pete
