Iowa Fair
bigmotors
08-15-2002 07:47:03
The pull starts at 08:00 A.M. ! Not at 09:00 A.M.
Alot of people have called about this. The weather forcast is uncertain at this time. We will try to have the pull; unless we get a down poor.
Hope to see you all at the fair.
bigmotors
08-19-2002 19:10:28
 Re: Iowa Fair in reply to bigmotors, 08-15-2002 07:47:03
Dear Pullers,
Before the pull started, two tech. people, and myself went to Bill Bear and asked to see the motor. Bear did so with no problems, and told me just about everything I asked. The motor is not what everybody thinks it is. Thou it is trick. Somebody did their homework. Bear was told this: if someone protests-you cannot pull. Bear did not have a problem with that. Some of the board members talked with the guys pulling against Bear. They did not have a problem with him pulling. So thats what happened. Bear's tractor didn't run that good anyway because of the 15% rpm rule. As for me not having balls, I guess your right-I should of kick your tractor out for having a 265 cu. combine motor in a 230cu. model Wards. Funny how life works an't it. As to last year, I agree 100%. Infact I was mad about the hole deal. But, the Big Big, Fair Board is the one that said NO. If you want more info. let me know. Thanks!
Nice job bigmotors!!
08-17-2002 13:39:26
Well, you chickened out on looking at the 460 and throwing him out!! We won't be back and will tell everyone else to do the same!!
rain the night before
08-15-2002 19:36:09
who was the Reaching Wizard that canceled the pull last year when the weather was nice and there were alot of people at the pull, ready to pull just blade off the track and pull, it was a beautiful day
Can our German diesel 460 pull there??
08-15-2002 12:38:34
Bigmotors-are u going to let german diesels pull?? Will anyone "look" at this motor to see if it is legal??? It'd be a good time to set the story straight and see if it is german or english?!?!
bigmotors
08-15-2002 16:00:24
 Re: Re: Iowa Fair in reply to Can our German diesel 460 pull there??, 08-15-2002 12:38:34
If we have a protest, and it is a 361 or 407, or what every block-the way the Iowa State Fair rules read-NO! We might let him pull, but not for trophy. I like the guy, and I would like to see it pull, but rules are rules. This is not a NATPA pull- it is the Iowa State Fair Pull, again-with Iowa State Fair rules. Everybody that entered should of recieved a set of the rules. I don't want to be a a-hole about it, and it should not have to come to that, but it's not right to the guy that went by the RULES, and built a 460/560 or 301 replacement block. We'll have to deal with it, when the time comes.
Take charge and protect YOUR pullers!
08-15-2002 20:36:31
 Re: Re: Re: Iowa Fair in reply to bigmotors, 08-15-2002 16:00:24
YOU and the pull committee need to protect your pullers that come to this event looking for a pull of its lattitude (state fair) to enforce rules! It is obvious that this tractor is supoposed to be illegal with ALL the talk!! You along with your pull committee should examine this tractor BEFORE the pull! As you stated, why make legal 460's and other models run against it. Yes, he is a likeable guy, but take charge, or does he intimidate you??? End this nonsense once and for all! Your actions will help pullers be treated fair later(if it truly is illegal) or end their worries! Why put the pressure on other pullers? If this was "Joe Blow" and not Bill Bear, I bet you'd look at it! Again, please take charge! We'll await your decisions!!
well said
08-16-2002 09:17:35
 Re: Re: Re: Re: Iowa Fair in reply to Take charge and protect YOUR pullers!, 08-15-2002 20:36:31
