Need more power in a hurry.
Kramer
07-30-2002 10:06:55
I have a 1952 JD A that I plan on pulling this coming weekend. I need some tips on how to get more horsepower before this weekend without having to take apart my tractor. Thanks
G Taylor
08-01-2002 19:25:58
 Re: Need more power in a hurry. in reply to Kramer, 07-30-2002 10:06:55
As long as it makes stock HP forget about the engine and pull in creeper gear. Worry about weight ,balance and hitch height/length. Tires will make or break a pull. The harder the track, the shorter and sharper the bars the better(usually).Rims should be as wide as the tire.
Tony
07-30-2002 14:09:20
Put a straight pipe on and open the load on the carb about a quarter of a turn. Let it roar. An A like you have should never run out of power with that creeper gear. I am pulling a 1936 John Deere A and it never runs out of power.
GET SOME OF TILLEY'S FUEL!!!!!!!!!!!!!
07-30-2002 13:26:14
1
Is it true?
07-30-2002 20:27:38
 Re: Re: Need more power in a hurry. in reply to GET SOME OF TILLEY'S FUEL!!!!!!!!!!!!!, 07-30-2002 13:26:14
Is it true that Tilley will be traveling the winter circuit this coming winter, NOT pulling, but as a fuel saleman for any puller needing a little "special" fuel!? Wonder if it will burn in all these german diesel with spark plugs in the their old injector holes? Surely noone would try to do that now would they?
YES OH YES!!!!!!!!
07-31-2002 14:37:20
 Re: Re: Re: Need more power in a hurry. in reply to Is it true?, 07-30-2002 20:27:38
yes oh yes, Tilley has come up with a mixture that will increase h.p. by as much as 40%! and is non detectable no matter what fuel test you use! now i have only been told these things, but it was from a very reliable source in n.c. also they said he is building another tractor that is very huhs-huhs! rumor is that it is funded by a big sponsor that wants to take brooks and bear to the cleaners! if anyone knows anything, please let us know!!!!!
Travis
07-30-2002 12:57:17
QUICK!!!- Go buy an Oliver!! J/K!! Good Luck
deere A puller
07-30-2002 13:18:36
 Re: Re: Need more power in a hurry. in reply to Travis, 07-30-2002 12:57:17
play with the timing, and the carb...good luck
A puller
Kramer
07-30-2002 15:22:18
 Re: Re: Re: Need more power in a hurry. in reply to deere A puller, 07-30-2002 13:18:36
Thanks for the help. I had an Oliver 88 before I got my A.
Oliver Puller
07-30-2002 20:43:56
 Re: Re: Re: Re: Need more power in a hurry. in reply to Kramer, 07-30-2002 15:22:18
I would hate to think I got rid of an 88 Oliver for a JD A !!!!!
kspuller
08-01-2002 09:47:24
 Re: Re: Re: Re: Re: Need more power in a hurry. in reply to Oliver Puller, 07-30-2002 20:43:56
AMEN TO THAT
Will
08-03-2002 18:03:42
 Re: Re: Re: Re: Re: Re: Need more power in a hurry. in reply to kspuller, 08-01-2002 09:47:24
I use to beet up on the Oliver 88s all the time untell they cried about my 37A. Now i beet up on them with my WC AC.
Eric Kramer
08-05-2002 17:18:36
 Re: Re: Re: Re: Re: Re: Re: Need more power in a hurry. in reply to Will, 08-03-2002 18:03:42
I took my A to the pulls this past weekend and got 6th place in the 5500# class. It was the first time i've pulled it and i beat Farmall 460's, JD 60's, and a couple of oliver 88's.
