John Deere G
Phillip
07-21-2002 13:23:11
How much to hubs cost? Do u actually need a pair?
Gman
07-22-2002 18:52:42
 Re: John Deere G in reply to Phillip , 07-21-2002 13:23:11
Phillip I assume you are wanting to put pressed steel wheels on your "G" right. If you have the cast rear wheels tha the hub is removable,all you have to do is seperate the hub from cast center and take a grinder and open the pressed steal wheel up were the hub will clear and get you an adapter plate. There is a guy that adverises in Green Magazine that has the adapters,or you might tru Mcalls welding in Winchester Ky 1-859-744-1049 he might be able to help you. Garland
