What octane gas for what compression?
JohnDeere2Cylinder
07-19-2002 11:04:28
I have seen many posts on this subject, but no answer to my question: What octane gasoline for what compression in psi? My gauge only shows psi, not compression ratio and the engine is an unknown ratio. For examples, if under 100 psi, what octane is recommended or if 100-125, or 150-200, or 250-300, what octane? Does anyone know of an accurate chart? Thanks.
G Taylor
07-19-2002 19:37:19
 Re: What octane gas for what compression? in reply to JohnDeere2Cylinder, 07-19-2002 11:04:28
It isn't the pressure but air/fuel mixture getting above it's ignition temperature. A 3 to 1 compression engine with 50 psi compression will detonate on 100LL aviation fuel if the mixture is heated by glowing carbon,too hot plug,glowing overhanging gasketor glowing exhaust valve. High rpm automotive race engines often retard timing near redline as more heat from compression ends up in the air/fuel mixture than at lower rpms. Same as diesel has to be cranked fast enough to start.
The Happy Hooker
07-19-2002 13:46:06
If you get above 175 or so psi you better run some good stuff. We have 2 old As running 215 to 235 and we run 110 octane or better. One of them has been known to ping on that.
G-MAN
07-19-2002 12:13:19
I don't think there are any hard and fast rules pertaining to octane requirements and compression ratio. There are too many variables within each engine. Things like bore diameter, piston shape, timing, valve location, plug location, engine temp and many other factors determine what octane is required, along with compression. Two engines could both have identical compression, but they could require completely different octane ratings, based on all of the different factors.
MMpuller
07-19-2002 19:28:42
 Re: Re: What octane gas for what compression? in reply to G-MAN, 07-19-2002 12:13:19
I agree , dont forget that a multiple spark will also help but their is nothing cast in stone for octane to psi
JOhn
07-19-2002 15:49:24
I would say that if you get above 225psi, you better come up with a different motor. We have a G that runs at a bout 205psi, and we have to run 110, 103 octane aircraft fuel is too little for it to handle.
John
