Tire question
slow smoke
07-14-2002 15:08:32
Have any of you had any luck with longbar/short bar tires? I tried a set, they seamed to pull good, but once they started to slip, i was done. any hints. they're 16.9/38's on a 16" rim. thanx
kspuller
07-15-2002 19:26:40
 Re: tire question in reply to slow smoke, 07-14-2002 15:08:32
90% of the time they don't work.
Greg H.
07-15-2002 13:26:46
There's no hints to give you that I know of. I used a set for two summers,until I could find a good set of tires that I could afford. I tried everything, but like you say once you start slipping in the slightest you wont go much farther. The only tracks I ever did well on were muddy,or soft tracks, and I think it was because they were about half tread, and could dig down. Good luck though. Greg H.
Puller504
07-14-2002 19:00:18
Hi slow smoke, we landed a pair of Firestone 23" short bar/long bar 18.4x26" tires AND rims (pressed steel) at the Wooster farm consignment sale this spring for $275. They did outstanding at the spring WSTPA pull in the 5000# and 6000# classes on the IH504. I understand that these tires are no longer made, (wear out quickly on roads). They outpull the Goodyear long bar tires we used last year, many more lugs per tire.
Roy
07-14-2002 16:37:45
Tried a pair of 16.9 x 34 long lug short lug with no luck. Stick with 23 degree Firestones.
