Propane head vs regular gas head
Mike Wells, NC
07-13-2002 10:40:54
Thank you in advance for any helpful information and insight.
I've noticed that some club rules state no propane heads on regular gas blocks. Why would someone consider changing heads? Is there any significant advantage to to be gained by installing a propane head onto a regular gas block?
Jim M
07-13-2002 12:57:04
 Re: propane head vs regular gas head in reply to Mike Wells, NC, 07-13-2002 10:40:54
On most Case tractors the propane head gives you one full point more compression than a gas head.
Andy
07-13-2002 22:27:05
 Re: Re: propane head vs regular gas head in reply to Jim M , 07-13-2002 12:57:04
You get more comp and more hp at higher rpms but it seems they don't lug as well as a stock head. Depending on what head you use you can have preignition problems with regular gas.
