Wc overbore
wanna be a pull
07-12-2002 15:22:36
I have been told that I can bore my Allis Chalmers Unstyled WC to 4.250 inches. Can anyone tell me where I can get pistons, rings and sleeves to acomplish this? Also, should I do any work to the governor? What should I do to the head? Should I put in larger valves and heavier springs, etc? If so,where can I get the supplies for this?
Todd
09-23-2003 10:30:39
 Re: wc overbore in reply to wanna be a puller, 07-12-2002 15:22:36
On ours we're running the chevey pistons, 45 cranks, and ported and polished head. It ran great then we put a 175 spring in the stock govenor. Made it touchy but made it a better puller. Got us 1st in the 4000, 4500, 5000 Modifieds this year.
Doug in OR
07-24-2002 20:11:39
Why not just put a WD45 crank, sleeves, and pistons in it? The extra stroke will give you more than the extra bore would.
rk
07-13-2002 23:57:00
4.250 is the bore of a big block chevy, and the wristpin end on the allis rods need to be resized for the larger wristpins, this will allow them to be used..lots of wc's running those pistons around here very tough. can bore factory sleeves out to that size but is very thin would be better if you had some made by darton or a specialty shop like that. be advised that the motor cant be run for long periods of time i.e. like idling for half an hour in the stage area..because of heat buildup from thin sleeves.
Flyin Farmall
07-13-2002 20:22:26
You need to get a hold of high altitude pistons for a d-17-180,a 45 crank,small block Chevy springs,and a few other goodies,E-mail me.
