Welding hubs on axle
Will
07-02-2002 12:39:06
Can some of you guys tell me the type of rod you have used to weld hubs on to axle shafts. Thanks in Advance
Pete1468
07-02-2002 15:36:10
 Re: Welding hubs on axle in reply to Will, 07-02-2002 12:39:06
Gussets are a must, at least 3. I wouldn't trust a stick welder, all of ours are wire welded and we haven't had a problem even up to the 10,500lbs class with an M.
TimC
07-02-2002 13:19:48
7014 with an AC welder or 7018 if you can get ahold of a DC welder. Just my opinion...
Gussets, at least three need to be installed.
