john deere 730d
UNSTYLED PULLER
05-19-2008 12:43:25
hello,,,
thinkin about buyin a 730d to pull,,,rules say 1st gear at 3mph,, is a 730 geared too high?
thank-you..
UNSTYLED PULLER
05-19-2008 13:17:40
 Re: john deere 730d in reply to UNSTYLED PULLER, 05-19-2008 12:43:25
THANK-YOU,,,
THAT WILL HELP A-LOT, I KNOW WHAT TRANNY TO START LOOKIN FOR,,,
gpuller
05-19-2008 13:01:23
730's came with a fast and slow first gears. If first gear is located above reverse in the shift quadrant it has the slow first gear.
If it has the low first you can run 2nd gear with 18.4-38's and stay below 3 MPH.
JD720D
05-19-2008 15:33:02
 Re: john deere 730d in reply to gpuller, 05-19-2008 13:01:23
I currently have this setup and have blown the horn at 3mph. Only running 10% over on rpm's also.
