RULE- hitch adjuster not to be above center of reae axle
MASSEY85
05-19-2008 04:37:01
this rule seems to be popping up at a few clubs around here this year. what is the purpose? what about the oliver77-88's the draw bar attaches above the rear axle from the factory. thanks for your time.
counterclockwise
05-19-2008 18:28:56
 Re: RULE- hitch adjuster not to be above center of reae axle in reply to MASSEY85, 05-19-2008 04:37:01
If safety is the reasoning behind a rule like this, why not require NATPA wheelie bars (that are independent of the hitch) and such a rule would not be needed.
xxdonxx
05-20-2008 01:53:26
 Re: RULE- hitch adjuster not to be above center of reae axle in reply to counterclockwise, 05-19-2008 18:28:56
NATPA has the same hitch rule.
Hoss in Me
05-19-2008 14:07:38
I pull a lot and agree with both points made. Hoss
Mike n Mo
05-19-2008 05:06:05
The basis for the rule is safety. If the hitch/drawbar were to break at the lower attachment point, and the drawbar was attached to the adjuster, you would then have a very high hitch point on the tractor. The chances if flipping the tractor over backwards at this point are pretty good. I witnessed this very scenario several years ago and it all happened in about a second. I know all about the argument regarding the factory attachment points, but I don't buy it. When you pull onto a pulling track, you're then in a competition on a prepared track pulling a load designed to stop the tractor, not in a field pulling a load that shouldn't load the tractor to the point of stalling. Another point is that just because it left the factory that way doesn't mean that it was a good design. The factory hitch was made consistantly, unlike homemade pulling hitches which may have a wide varity of designs and quality. What if the factory bolts have been replaced over the years with lower quality bolts? Some guys may check things like this and others may not.
I realize this may be a big controversy with others, but this is my $0.02 worth. Mike
Good point
05-19-2008 06:08:00
 Re: RULE- hitch adjuster not to be above center of reae axle in reply to Mike n Mo, 05-19-2008 05:06:05
That is why most of us will make the adjuster the weakest point. If propoerly designed there should not be a lot of stress on the adjuster.
