Super M compression
oliver77
05-16-2008 03:39:28
I"m building a super m with denny"s pistons (4.310) and a half inch of stroke. I"m also running a 450lp head that has bigger valves and a lot of port work. It has a cam from bullet cams in it too. What kind of compression should I be looking for on each cylinder? I"m not having the block decked or the head shaved. Thanks for the input.
Dblair
05-16-2008 13:15:48
 Re: Super M compression in reply to oliver77, 05-16-2008 03:39:28
9.7 with a international head gasket.
rcw
05-16-2008 12:12:33
190# cranking pounds. I just run high test gas.
Hoss in Me
05-16-2008 06:52:01
I built same thing.Didnt care what compression was,put high test in it and run her! Have fun,Hoss
superih
05-16-2008 06:49:55
335 cid. With flat top pistons coming flush to engine deck, 140cc head, compression should be 10.8/1
