H wheel weight atachment?
daniel gillespi
05-14-2008 18:20:23
Hey does any body have a picture of the way to attach the rear wheel weights for a pulling set up. I saw one some time ago that used two pieces of 5'' channel iron to make the supports then bolted it on the rear rim with the 4 bolts. Pictures are worth a thousand words in this case. I can build it but I need pitures to sorta get the idea!!
John B. NE Ind.
05-17-2008 02:44:29
 Re: H wheel weight atachment? in reply to daniel gillespie, 05-14-2008 18:20:23
We used threaded rod thru the 4 bolt holes when we pulled our M. Cheap and easy!
ChadS
05-15-2008 08:14:02
third party image
Hope this helps. ChadS
daniel gillespie
05-15-2008 11:23:35
 Re: H wheel weight atachment? in reply to ChadS, 05-15-2008 08:14:02
do u have one w/o the weights??
ChadS
05-15-2008 16:02:13
 Re: H wheel weight atachment? in reply to daniel gillespie, 05-15-2008 11:23:35
None that I know of,,,, LOL!! Just picture 2 hidden parts,, at the end of the channel a 1/4 plate welded/gusseted bolted to the stock weight hole to the cast center,,,, right in the middle of the bracket, another 1/4" plate with an axle hole cut in it for extra support. Chad
