450 LP
kendak
05-13-2008 05:28:22
found a 450LP Farmal at scrapyard ...how do you tell if it has the right LP head....numbers ????
james rumph
05-13-2008 07:00:53
 Re: 450 LP in reply to kendak, 05-13-2008 05:28:22
I don't know the head # but the divorced intake / exhaust manifold is worth a pretty penny if it's not cracked .
Meaning: both tracks are seprate so the exhaust doesn't heat the intake .
ChadS
05-13-2008 07:10:57
 Re: 450 LP in reply to james rumph, 05-13-2008 07:00:53
Where the manifold bolts to the head, on any other heads, you would not see the actual ports from the outside casting,,, the Lp heads, you can see the port runners casted and see em from the outside at glance.
