petcocks
jdfarm
05-12-2008 09:07:13
Can anyone tell me if I can drill and tap the side of a block to install petcocks on a john deere 60? Want to put plugs in the bottom so I dont have to reach under there every time I want to crank it.
Mike n Mo
05-12-2008 15:54:07
 Re: petcocks in reply to jdfarm, 05-12-2008 09:07:13
You can do it with a power block, but I think you'll be opening a big can of worms on a stock block. I don't think there's anywhere you can go thru directly from the outside to the cylinder wall without going thru water. To do it I guess you could weld in a short pipe, and weld it on the outside, and on the inside cylinder wall. to get it to seal water without the weld cracking during the heat cycles would take an experienced welder. My $0.02 worth, Mike
