limited slip for AC-WC
mo-ac
05-07-2008 17:34:58
Does anyone know about limited slip or posi traction for a WC Allis?
Kip-Utah
05-08-2008 20:46:35
 Re: limited slip for AC-WC in reply to mo-ac, 05-07-2008 17:34:58
You just need to learn to do the hand brake dance!!
ChadS
05-09-2008 06:38:13
 Re: limited slip for AC-WC in reply to Kip-Utah, 05-08-2008 20:46:35
On a WD45, I had split the differential, bought a clutch pack rebuild kit for a 5.0 mustang,, with a 8.8 rear end. Placed one half in the lathe, and cut enough area out to fit the disk behind the spider gears, I think I left .030 of the disk sticking out,,, (did that to both halves) Put it back together and seemed to work out real well. In the ford clutch kit, you get alot of those friction disks,, so you wont run out for a while,, but over time,,, the disks will wear and need replaced. If it does not get driven much, it would last a long time, but if its driven all the time,, and the more turns ya make, it will wear faster. I dont know if the WC is the same carrier as the WD45,, hope this helps,,, ChadS
