John Deere g
Zap
05-05-2008 05:44:37
Is there anyone out there that makes a gear setup between 1st & 2nd gear? First gear is to slow and second is to fast.I Run 3mph is the classes. Have 15.5x38 tires. I would like to run 3mph at 1100 Rpm"s in 2nd. Thanks for the help.
gpuller
05-06-2008 06:54:22
 Re: John Deere g in reply to Zap, 05-05-2008 05:44:37
Hot Rod A said: Tire up and drop to low for 3mph. 3mph in 2nd gear at high idle is a tough task, and you'll be running either a very small tire, or at least a very small diameter tire. If rules allow, go for a set of 16.9-38 tires and run first...or build her up and idle in 2nd.
I believe 16.9's would be too fast, and you'd have to throttle back. It would take a stout G to run 16.9's in a 3 MPH class. I have had the horn blow running 14.9's.
gpuller
05-05-2008 06:18:23
If you can switch to 14.9-38's, that would put you at 3 MPH in low gear.
2 Cylinder
05-05-2008 09:50:12
 Re: John Deere g in reply to gpuller, 05-05-2008 06:18:23
I would go to 16.9-38"s if the rules allow and you have enough power. That is the tire size I run, my G is only 70 hp.
Hot Rod A
05-05-2008 22:32:07
 Re: John Deere g in reply to 2 Cylinder, 05-05-2008 09:50:12
