HI ! I don't know Bob, and I don't know the author of this thread... so I have no dog in this fight. Given that, I'd love to know more about the situation. You made a very passionate statement concerning your situation. You said you were dealing with a "rotating assembly". In my mind, that is the block, crankshaft, rods and pistons and possibly camshaft. You said you were dealing with a tall deck block. You said the parts were "wrong". I'd like to know specifically what was wrong ? You made some reference to it being a "tall deck", and Bob didn't know it was a tall deck, but you told him it was a tall deck. Given that, and given your reference to the parts being "wrong", I would assume the problem has something to do with deck height and compression distance ? The deck height difference (between a tall deck and normal deck block) is considerable, nearly 1/2 inch if my memory serves me correctly. If you are dealing with a 454 stroke (4.25 inch), the compression height for those pistons is 1.647. For a 454 tall deck block, the piston compression height is 2.040 to accomodate the taller deck height. That's a whopping difference! Meaning, it would be clearly obvious to anyone assembling the rotating assembly... should they have the wrong parts. IE: the pistons would be sticking up out of the block... or be way below deck surface.. at TDC ! Now, I realize you are dealing with a aftermarket Dart block (probably Merlin), and I may be off on my compression height, esp IF you are using a different stroke, etc... but my "theory" holds water either way as the deck height difference is SO dramatically different when speaking of a tall block, that any fool could see if they have the wrong parts when it comes to compression height. So please.... explain the details ! I'll be looking forward to your reply. And, let me appologize in advance if you have some crazy custom rotating assembly that falls outside the limits of normal 427/454/502 stroke and compression height/ rod lenght/ that would allow for such a mistake to escape the trained eye.
I'll be waiting for your reply ! Mark Osborne Osborne Auto Fraser, Michigan
