1st pull
c35
04-29-2008 09:33:31
I have just put a Cockshutt 35 back together and considered maybe doing a pull at the local Fair come August.
Its a all stock machine no alterations.
Where would I start in regards to tire pressure and groundspeed
1st gear or 2nd
Not looking to campaign this just make a couple decent passes and not make a fool out of myself
Blackhawk 35
05-12-2008 17:53:45
 Re: 1st pull in reply to c35, 04-29-2008 09:33:31
I have a 35 also and first gear goes 1 5/8 mph according to the manual and second goes 2 3/4. This is from an original manual. So considering most speed limits are 3 mph i would pull in 2nd. I havn't pulled much but 2nd seems to work much better. Also if you want to get crazy you could go in 3rd wich is 3 5/8 mph. but i highly doubt you'll have that much power stock.
utupuller
05-05-2008 22:06:05
for stock antiques or close to stock, use first gear. The slower the better
UNSTYLED PULLER
04-29-2008 15:53:07
HELLO,,
I PULL DEERE, BUT I RUN 10 lbs of air and are farm stock class rules say 1st gear only,,
hope this helps,,
c35
04-30-2008 10:56:26
 Re: 1st pull in reply to UNSTYLED PULLER, 04-29-2008 15:53:07
1st is awfully low on this , I'd figure 2nd would get the sled moving a bit better?
Tires are stock 13.5 x 38
garytomaszewski
04-30-2008 17:53:23
 Re: 1st pull in reply to c35, 04-30-2008 10:56:26
Low gear has always been the gear for heavy load moving, most engine RPMs per revolution of rear tire= more engine power/revolution of tire. Reduce tire pressure to get full contact of the lugs without buckling the center of the lugs
c35
05-02-2008 03:48:31
 Re: 1st pull in reply to garytomaszewski, 04-30-2008 17:53:23
so its more straight pull then getting the weight moving and keeping it in motion then?
The small anmount of pulling I have seen I figured you had to get the weight started well and then some groundspeed to keep it from digging in.
