tire size for wc wd allis for pulling
scott reid
04-29-2008 07:49:18
looking for someone pulling wc or wd allis whats the best tire size to run
mlpankey
04-29-2008 12:00:15
 Re: tire size for wc wd allis for pulling in reply to scott reid, 04-29-2008 07:49:18
depends on what mile an hour you want to run . if you want to stay geared low try 18.4/26 . if you want to run 5 mile an hour in first gear use 15.5 38 or wider. or find a rc gear or sherman box for a wc then run the taller tires if its a wd run the 45 diesel gear and tall tires.
Larry Mc
04-29-2008 11:42:02
Depends on class and or local rules. In the low weight classes 13.9 x 38 or under 14.6 x 38 for heavier classes Some run 34" some 28?" rim size. Sorry, not a standard answer. Look at what the others are running in your class and adjust.
