spark plugs for Unstyled tractors
jdeereletters
04-28-2008 16:31:05
I was just wondering about what spark plugs would be the best ones for my unstyled G besides Champion plugs. I have W-18 Champions in it now but if I could find a different plug option to use I would. My tractor is stock displacment with the old cast pistons in it. It does have a little bit of a cam and a late G carb on it. I was wondering about using those adapters for the plugs but couldn't find a contact number for them and didn't know what plugs to use once I got them. Any info would help thank you
730-LP
04-29-2008 12:01:12
 Re: spark plugs for Unstyled tractors in reply to jdeereletters, 04-28-2008 16:31:05
I can't remember the # but the champion plug that they use in a Int. bulldozers that start on gas and runs on diesel works real well. 89D??
UNSTYLED PULLER
04-28-2008 17:35:29
HELLO,,
I PULL A UNSTYLED -A- I RUN A AUTOLITE 3077,,
I HAVE NOT HAD ANY LUCK RUNNIN A LIGHT COLORED PLUG,, ALWAYS RUN A DARK PLUG,,
TVMAN
04-28-2008 17:00:51
I run w-89-d champion had good luck. Hope this helps
Gary from Muleshoe
04-28-2008 16:53:08
I run Autolite 3077 in my 1940 B. Not sure if they would be hot enough for your G or not. I have heard people talk about using them in A's. I got mine through NAPA Auto-parts. They should be able to tell you what will work in the G also.
