farmall H alternator conversion
newhpuller
04-28-2008 05:29:33
Im trying to install a small alternator on my farmall h, I have removed the pully off my water pump because i went electric on my fan and my pump. I cant find space to run it off my lower pully only, Mu oil ffiller is in the way, some help is needed. can i put it on the left side or can i put it under the frame????? ???
LCB
04-28-2008 11:04:40
 Re: farmall H alternator conversion in reply to newhpuller, 04-28-2008 05:29:33
I have a freind who moutned one right under the crank pulley. You can see it hanging there but he used a crome one and looks good.
elijah
04-28-2008 10:04:05
I don't know if I completely understand your question but you can mount an alternator anywhere and any way as long as it turns the correct way and at enough rpm's to charge well Hope this helps eli
