New to pulllin
jh
04-27-2008 17:57:20
I have am having a problem get my power to the ground on my case it loves to spin out to easy what is some simple rules to go by
alliswd45
04-28-2008 18:38:22
 Re: New to pulllin in reply to jh, 04-27-2008 17:57:20
higher gear
mmpuller
04-28-2008 10:30:31
What is the max tire size you can legally run in your classes?
mmpuller
04-28-2008 10:28:06
Try taking some weight off the front end, and moving it too the back. Also it may be that you have too much air in your tires. I like the 18.4 34 deep treads, but as with any tire finding the sweet spot on air pressure can be tricky. After your next hook, have someone go out and kick open your tire tracks, not where you spin out, but right in front of the sled, and see if they are humped up in the center, or flat. You want them flat as far as I'm concerend. If there is humps in the center than you don't have enuff air.
1958johndeere620
04-27-2008 18:27:53
Air pressure, Hitch height, length, weight placement, add weight to a heavier class. Every association has diffrent rules. Read yours and figure out what things you can legally change. HAVE FUN!!!! THATS WHAT ITS ALL ABOUT.
Hoss in Me
04-27-2008 18:03:13
Wider rubber! Hoss
jh
04-27-2008 18:18:50
 Re: New to pulllin in reply to Hoss in Me, 04-27-2008 18:03:13
well i am already workin with 184 34 firestone deep treads
560 Farmall Puller
04-28-2008 17:31:13
 Re: New to pulllin in reply to jh, 04-27-2008 18:18:50
In my opinion yhe deep treads are your problem. Had a set and that was my problem spinning out way short of everyone else. Changed to Firestone Field and raod and won 3 classes last year. And they were 15.5- 38.
MN Dave 2
04-27-2008 18:55:04
I don't know what class or weight you are pulling, but you might have too wide of rubber on now. On my tractor I have 18.4X38 and in the 6500 stock, I can't get enough weight on so I usually will spin out much easier than I will in the 7000 or 7500. The above post said it quite well, all the variables will make it fun while it drives you crazy. Welcome to pulling!!!
jh
04-27-2008 19:01:32
 Re: New to pulllin in reply to MN Dave 2, 04-27-2008 18:55:04
i pull in 8200 9200 10200 classes
