PROPANE EXHAUST MANIFOLD
doorman
04-27-2008 16:44:15
Will a propane exhaust manifold that is separated from the intake manifold on a "60" series Farmall increase performance any in stock or superstock classes? Also how much does the elbow that turns down on the outlet restrict flow? Thanks, doorman
ChadS
04-28-2008 05:19:51
 Re: PROPANE EXHAUST MANIFOLD in reply to doorman, 04-27-2008 16:44:15
Cooler incoming air from the separated manifold, some exhaust manifolds had 2.5 outlets, most had 3 inch outlets. the LP intake has bigger ports thru the carb flange VS any gas manifold. Im sure VS a gas manifold in stock form, the LP setup can help you, I dont know on turbo charged engines, but worked real well for a naturally aspirated setup. Hope this helps a little. ChadS
