Rules designed for elimination of whinnnnning
MN Dave 2
04-27-2008 10:01:02
After talking to a puller who hasn't pulled for a couple of years because he got sick of the whinning and the high $$$ spent on the "stock appearing" open tractors, I found myself agreeing with him more and more. It made me think of how to make our sport more fun and enjoyable for both new pullers and more experienced ones, therefore I came up with theses rules.
My rules will have 3 classes only with a short explanation for them.
Farm stock
Simple...if it didn't come from the factory before 1960 (1959 and older tractors) you can't use it and you have to pull it in it's origional form (tire size, no cut tires, mufflers, air cleaners, blocks, heads for that model, drawbars for that model/year) NO suitcase weights, turbo's ,blowers unless it came that way. Must pull with a hitch pin/clevis. Tractors can't pull in class less than their origional shipping weight.
If you limit the hitch height to max 16" high and mimimun 24" back from axel center, you should make it even for everyone. My intention is to make it possible for first time pullers to be competative.
Hobby stock
Class is intended for more experienced pullers. Tractors 1960 and older, single bias tires 18.4X38 max size and NO CUT OF ANY KIND (road wear ok, but if it's been touched by any type of machine-not allowed), hitches 20" & 18", origional appearing Block and heads and carb for that model tractor, no weights further than 24" from front of tractor (The 11' from center of rear axle could work here also) wheelie bars are required, RPM's 10% over stock.
Open
Tractors 1960 and older, no duals, tracks or chains 18.4X38 bias tires max, any rpm, any gear, any engine, any cut on tires. No blowers, turbos, or injected fuels unless tractor came with it. Tractors MUST have safety kill switch, wheelie bars, safety scatter blankets, dead-man throttles.
My idea is to eliminate the "size if checkbook" factor that is killing local tractor pulling. I feel it is foolish to spend $20K or more on a "stock appearing" engine when $1500 will put a different engine combination in there. (IF you want to spend the $$$, go ahead, most of us can't afford it).
What would you change with the above rules?????
KW-TRUCKERMAN
04-28-2008 16:21:58
 Re: Rules designed for elimination of whinnnnning in reply to MN Dave 2, 04-27-2008 10:01:02
Hi, not a bad start,Dave. U might consider dividing the open class by # of cylinders, and engines. Need mph limit on stock class! And what about the guys with radial tires?
gpuller
04-28-2008 09:56:41
Speed limit is a must have in the stock class and even the farm stock. NATPA speed limit for Div 2 is 3 mph, and no shifting.
buickanddeere
04-28-2008 06:23:49
Add in a mph limit to wean out the cheaters.
jd b puller
04-27-2008 21:25:31
 Re: Rules designed for elimination of whinnnnning in reply to VA PULLER, 04-27-2008 10:01:02
I thought you were trying to get rid of the whining? Hobby stock saying "no cut tires".... Have fun with that one. "No, mine are road wore", "no they aren't you cut them..." "You son of a ... Yes they are"...
Cut tires is the fairest way to do it. You don't have to search for months trying to FIND a set of tires naturally sharp, you just make them the way you want and you can't call anyone a cheater.
You need RPM limits for safety reasons.
Looks like your open class would be a V8 classs...
Allison Aircraft
04-27-2008 15:19:40
Any engine think 1710cid.
MN Dave 2
04-27-2008 17:40:32
 Re: Rules designed for elimination of whinnnnning in reply to Allison Aircraft, 04-27-2008 15:19:40
Speed limits..... farm stock- first gear
hobby stock... 1st gear should take care of it or second if tractor is equipped with a creeper 1st gear, also if tractor came equipped with a TA type shift, use it.
Open class, I'm not sure if you need one, maybe 15-20 mph would keep the huge money out of it. Perhaps the "run what you brung and hope you brung enough" rule should apply here.
RichH
04-27-2008 14:43:20
And if you put a 3 mph on the farm stock tractors, the lower hp stock tractors will do better most of the time. At our pull some div. 2-3 tractors TRY to pull div. 1, but at lower rpm they fall flat on there face and when they open them up at the end they just spin out. We get alot of old just out of the shed local tractors at our pull because of the 3 mph rule.
Hartsburg Hammer
04-27-2008 13:30:33
Got any speed limits in mind?
toolz
04-27-2008 21:15:49
 Re: Rules designed for elimination of whinnnnning in reply to Hartsburg Hammer, 04-27-2008 13:30:33
Are you from Hartsburg IL? I grew up there.
kruser
04-29-2008 17:37:42
 Re: Rules designed for elimination of whinnnnning in reply to toolz, 04-27-2008 21:15:49
toolz,
Not very often you see Central Illinois on this board but I grew up in the "big brother" city of Emden, IL. Shoot me an email when you get a chance. Getting ready to see if the Olivers will run for the Mackinaw River circuit.
Jim K
toolz
04-29-2008 18:55:23
 Re: Rules designed for elimination of whinnnnning in reply to kruser, 04-29-2008 17:37:42
Jim- No email with your post, but if you see this, shoot one back. I'll be at the Mackinaw pulls this year also. Thanks- Kevin
kruser
04-30-2008 06:47:50
 Re: Rules designed for elimination of whinnnnning in reply to toolz, 04-29-2008 18:55:23
Oops - Forgot that part!
Hartsburg Hammer
04-28-2008 13:05:35
Sorry, I'm a Mizzou Tiger.
