'63 Fordson Super Major
Mark Myers
06-27-2002 10:24:52
I am currently rebuilding the engine in my '63 FSM. My main goal is to put her back to work on a small farm here in Tx, but plan on playing a bit as well.
While I have the engine torn down, does anyone have any suggestions for tweaking a 220 CID Dagenham Diesel for best overall performance in the field/pulling??
Thanks,
Mark
BTW - Low gear is 123:1, no aux weights, and just a very stock tractor.
Paul Larson
06-06-2006 18:12:20
 Re: '63 Fordson Super Major in reply to Mark Myers, 06-27-2002 10:24:52
Can anyone help me? I have an old Dynahoe Backhoe/loader. I think that it has a Dagenham diesel engine. How do I identify this engine and if it is where can I get repair parts, Overhaul kits. It has Ford logo's stamped on some parts, the injectors are under the valve cover, the Injecton pump is Simms, driven on the right/passanger side of the enigne, it is coupled to a Ford-0-Matic.
Thanks for any help!!!!1
Andreas Gassner
12-08-2003 14:13:53
Hello my name is Andreas Gassner. i came from Stockerau in Austria and i am searching for a original VACUUM BREAKING EQUIPMENT for my Fordson Super Major 1962 i am very happy when you can help me about my problem! greats from Austria Andreas GASSNER
57fmd
06-29-2002 13:46:30
It will have do fine if you leave it stock. I pull my '57 Major in the 6 mph 5000lb class and it spins on most tracks. I am usually up near the front and occasionally win.
TimC
06-28-2002 14:21:59
Does it already have that big (i think) Simms injector. My dad has what i think is a 62 super power major. VERY strong for a 4 cylinder.
Mark Myers
06-28-2002 23:10:29
 Re: Re: '63 Fordson Super Major in reply to TimC, 06-28-2002 14:21:59
It has the Simms Minimec Inline injector pump.
Mark
David Ransom
06-28-2002 11:24:25
I think a Ford Super Major is what the township road crew used around here until recently when they switched to a much newer Massey Ferguson.
ford man
06-27-2002 20:34:36
Why would you want to do that to a major. They are a really neat tractors. Where do you get parts from down here in TN we can not find parts so we don't use own major much. Our major is a diesel also , and it is a 1960 fordson super power major.
Thanks
Mark Myers
06-28-2002 04:24:13
 Re: Re: '63 Fordson Super Major in reply to ford man, 06-27-2002 20:34:36
The parts are around, but mostly found in England, Canada, and Australia! If you would like, I can send you some links to my favorite websites for parts.
Mark
mike weatherspoon
11-08-2005 19:37:50
 Re: Re: Re: '63 Fordson Super Major in reply to Mark Myers, 06-28-2002 04:24:13
you can get almost any part for the super major or any tracto at www.yesturdaystractor.com search on google you will find it
