Fuel pressure on a Stromberg Carburetor
sls
04-25-2008 15:52:32
What is a safe fuel pressure for a Stromberg carburetor? It is a NAR9B
james rumph
04-26-2008 18:00:32
 Re: Fuel pressure on a Stromberg Carburetor in reply to sls, 04-25-2008 15:52:32
No there isn't any drop in fuel presure. I'm only spinning the motor up to 2000 rpm , unlike a car motor that may go 7000 rpm.
I have turned the fuel presure up to 10 psi and the needle held it back , but that much presure isn't needed in this application.
My motor isn't crazy so do i need a electric pump ? I do believe it makes a differance .
james rumph
04-25-2008 18:38:47
I have been running 5 to 8 psi with out any problem with a Malory electric pump and regulator.
I mounted a small fuel presure gauge off the reg so we could watch it while we were running it on the dyno.
sls
04-26-2008 03:44:19
 Re: Fuel pressure on a Stromberg Carburetor in reply to james rumph, 04-25-2008 18:38:47
James, When doing a dyno pull do you see alot of fuel pressure drop under a full load.
