MSD Wiring
tops
04-24-2008 15:35:42
Is a ballast resistor required with a pertronix pick up and MSD ignition and coil? The MSD wiring diagram doesn't show one.
Ed Hodge
04-26-2008 05:41:13
 Re: MSD Wiring in reply to tops, 04-24-2008 15:35:42
no you dont need a resiter with the msd box
bm3501466
04-25-2008 07:38:44
I have a capacitive discharge box. You are wasting your time using a pertronix pickup for firing. Just use the points pick up or get a flywheel sensor if you really want to do it right.
Life of Riley
04-25-2008 06:01:26
What tractor are you putting it on?
Binderdog
04-24-2008 19:07:05
Do yourself a favor and throw the pertronics in the toilet. I have seen them not perform properly on more than one pulling tractor.
Mr. Juggs
04-24-2008 17:04:11
Make sure you cut the appropriate wire(inside the Msd box) for the cylinder setting(4,6,8).
mlankey
04-24-2008 16:23:22
no do not use one. wire it up just lie the diagram
Sweeper
04-27-2008 13:16:35
 Re: MSD Wiring in reply to mlankey, 04-24-2008 16:23:22
Get yourself a good set of wires, not solid core. I bought a set from Summit for a chev V-8 and had enough for two M's and a John Deere. They were MSD wires.
