smaller tires on 77
ERIC60I
04-19-2008 18:15:23
new to pulling,second season. would smaller 15 inch tires and rims make much difference over the 16 inch. have cut the hitch so it meets the 18 inch min. and have adjustmrnts for heights. thanks.
Mike n Mo
04-19-2008 19:54:47
 Re: smaller tires on 77 in reply to ERIC60I, 04-19-2008 18:15:23
Can I assume you mean 15.5X38 vs 16.9X38? A lot depends on what weight class, cut tires or not, and type of dirt/track you'll be pulling on. 4500# and up I'd proibably go with the bigger tire. 4000# could go either way. Mike
ERIC60I
04-20-2008 06:19:19
 Re: smaller tires on 77 in reply to Mike n Mo, 04-19-2008 19:54:47
sorry about the confusion, i am looking at changing the fornt tires to lower the front end. i have firestone 13.6 x 38's on the rear. last year it would get off the ground to fast.look to slow that down and maybe get allittle futher down the track.thanks
Dangerous
04-20-2008 06:54:02
 Re: smaller tires on 77 in reply to ERIC60I, 04-20-2008 06:19:19
Pulled a similiar set-up on a 77 with 400x15's on the front. Bought from Miller. If I remember it lowered the bolster area about 2 inches.
Good Luck
770
04-20-2008 06:29:05
Yes, you can put 15" tires and rims on the front. it will lower it a little, and you will drop almost 30 lbs.
