new farmall m motor
red binder
04-18-2008 12:32:58
what is the best set up ? bore and stoke with lp headi am lookin at a 4.38 x 7"
Gary Baker
04-19-2008 06:15:32
 Re: new farmall m motor in reply to red binder, 04-18-2008 12:32:58
421 is a popular size. Quite durable, my first M I built around 1995 is still running and never been apart. Make sure you sonic test bores to measure wall thickness. Not all 264-281 blocks will allow a 4.375 bore. Wall needs to be a minimum of .125 to hold up and hard block half way. Hope this helps
Dblair
04-18-2008 17:59:54
Murphys will give you a 4.312 x 6.75 will no clearance work
