MP 170, MTK, Which tip? .9mm, 1.1mm or 1.3mm?
scott#2
10-01-2005 16:25:41
Got everything staged, tables, hanging wire, paint stirred, cups waiting. Rod, CNKS, PaulW, whats you best guess as to tip size for the MP and the MTK? Keep in mind I'm using a Turbine system, siphon gun, not a shop air HLVP system. I know what the tech sheet says but I would guess all bets are off on that since it I'm not using shop air. Any guesses where to start? I need to go to Baltimore tomorrow to get a big electric motor. if I get back early, maybe I can shoot it all.
Thank You,
scott
PaulW_NJ
10-02-2005 18:32:26
 Re: MP 170, MTK, Which tip? .9mm, 1.1mm or 1.3mm in reply to scott#2, 10-01-2005 16:25:41
Scott
I have been using a Wagner turbine HVLP gun. I found the 1.3 mm tip to work very well for MTK, MP 170, as well as MP 182. I have mixed all of these exactly as the PPG spec sheets state, and aside from having to switch to a slower hardener with the 182 when the temperatures climbed above 85 this summer, I have not encountered any problems (other than my technique . . ). It depends I would think upon what pressure your turbine puts out. Mine has a 3 stage turbine that operates at 6 psig. Hope this helps.
Paul
Frank Stalfire
10-01-2005 20:33:31
Use the 1.1 if you have it, the turbines cant atomize by blowing the paint apart there is no velocity so you have to atomize by the tip size, use a small one so it will break up the paint to the size you want, you will also want to use a slower reducer and activator than normal since you are relying on the paint flowing out to get the finish flat not the velocity of the droplet
Frank
Rod (NH)
10-01-2005 19:29:45
Scott,
I have no idea what the differences are, if any, on recommended tip sizes between turbine and regular compressed air spray guns. Certainly you ought to be able to use the same tip size for both the epoxy and the MTK. They are not that much different, viscosity wise. I use one tip size on my regular spot gun and it does fine on both products. In most instances for typical automotive type primers and paints, one tip size will suffice as a "general purpose" tip - at least it used to before the advent of hvlp. My only suggestion is to review the instructions that came with your turbine setup. There should be some guidance on tip sizes there, if indeed, more than one size is provided or offered. If you don't have the instructions, see if the manufacturer's website has a manual for your model that you can download.
Rod
CNKS
10-01-2005 17:31:59
I wish I could help you but I can't ---
scott#2
10-01-2005 17:36:53
 Re: MP 170, MTK, Which tip? .9mm, 1.1mm or 1.3mm in reply to CNKS, 10-01-2005 17:31:59
I guess its just going to be a try and see thing.
scott#2
