Re: Question about Orange Peel
Rod (NH)
07-26-2005 18:36:13
MR 186 should be fine for 70 or even 70+ some. It's the most common reducer I use for MTK. PPG doesn't do well in recommending temperature ranges for their additives in the OMNI line. Fast, medium, slow, etc. are not that descriptive. I have asked PPG before on the matter and got a non-responsive answer. Here's my own crude numbers for reducer and hardener that I have penciled in on the tech sheet:
MR185 - 60-70 deg F
MR186 - 70-80 deg F
MR187 - 80-90 deg F
MR188 - 90+ deg F
MH167 - 60-75 deg F
MH168 - 70-85 deg F
MH169 - 80-95 deg F
If it seems to be in the higher end of a range at the time of painting, I may choose to use the next hotter product. However, I wouldn't go hotter than MR186 at 70 deg. Since I do everything outside and am extremely dependent on the weather, I keep MR186, 187 and MH 168 on hand as the most likely to use. I don't like painting at all below 70 or above 85.
The gun I've been using for all the work on my AC-B so far has been my spot gun. That's an HVLP model so I doubt it's an issue of HVLP vs. non-HVLP. For a spot gun it has a good sized pattern at 4-5" but it's still less than the typical pattern for a full sized gun. I don't think it's an issue of pattern size either. Perhaps I am confused with your use of the term "overspray". To me, that suggests a dry, rough spray rather than orange peel. If your problem is a little orange peel in your "overspray" areas, then you are probably correct although I have not noticed that as a problem as far as any overspray is concerned. I think my own problem with orange peel in the clear resulted from holding the gun too far away and having too fast a travel speed - on a consistent basis. Not getting enough material down quick enough and wet enough to permit the best flowout on the first coat. I noticed it and tried to correct by compensating on the second coat but failed in the effort. I suppose if you are at a poor spray angle, that the overspray that you mention can result in the same effect as being too far from the surface. I have just never noticed it. I would expect the overlap on the next pass, which should be within seconds, to melt it in well - that is unless the next pass is also to far away for some reason. I have not had an orange peel problem with the MTK or even with the MC on any of my AC-B sheetmetal to date, including the gas tank - except that once with the MC on the fender. Anyway, I don't have an answer to your problem.
CNKS
07-26-2005 19:42:00
 Re: Question about Orange Peel in reply to Rod (NH), 07-26-2005 18:36:13
I think it is simply a matter of not enough practice. I implied that I had orange peel when I responded to the initial post. The term overspray, or dry spray is probably more appropriate. When I spray a hood, I will typically start at the bottom of one side then work up the side, over the top and down the other side -- lengthwise, not crosswise. I am probably ok until I begin to work down the opposite side, then at the final curve of the hood, "overspray" can (not always) strike the newly painted top surface at the wrong angle, resulting in about the same thing as happened to your fenders, only worse. Actually, spraying the hood crosswise might help, provided I can keep the gun perpendicular as I go around. On a long hood that means more, shorter passes, and for me, more chances to screw up -- but, I have done that on a grille with pretty good success. The person who suggested the smaller tip is a person, who, like yourself, has painted for a long time -- I used to correspond with him by email. Only difference is that he uses the same HVLP gun as I do, he also likes PPG Omni. Otherwise you two are on the same page, all of the time.
Rod (NH)
07-27-2005 16:47:30
 Re: Question about Orange Peel in reply to CNKS, 07-26-2005 19:42:00
I find your problem somewhat interesting simply because I don't think I've ever experienced it. I would never think of doing a hood perpendicular to the long side - it would seem to be oh, unatural to me :o). The only time I've gotten into doing a hood crosswise is with my truck - and then only because the Centari that I was using at the time recommended a cross-coat technique where the second coat is applied perpendicular to the first. I think that's kind of wierd since I believe it is impossible to do on a full sized vehicle with the hood in place. My arms are not six feet long. Most people's arms are not that long either. The hood I did was done off the vehicle so I could do the cross-coat technique fairly easily. I did my B hood from the tractor similar to the way you mention. Lengthwise passes starting at the middle of the top, proceeding down one side, then moving to the other side and beginning where I left off in the middle of the top, continuing on across the top and down the other side. No problem with either orange peel or dry spray. I was using my spot gun because the size didn't warrant setting up my full sized gun with pressure pot. Actually that sequence is not much different from doing a car - top down - for instance the roof first, then the hood and trunk, then on to the sides. Inevitably, in doing the sides after the hood, around the fender areas, there will be some "overspray" get onto the previous painted hood areas at a less-than-perfect angle that puts the gun-to-surface distance a little more than desired. The extent of that would be greater with larger fan patterns. I just haven't had a problem in doing it that way, even with a 14"-15" large pattern on a VW beetle. I suppose one could start the hood by doing a full pass down the top side on the fenders, then up and over to the center of the hood and repeating on the other side - then go back and finish the lower portions of the fenders. In other words, ending in the middle top of the hood rather than starting there. I have never tried it that way.
It would seem to me that no matter how you approach it, transitioning from a vertical surface to an attached horizontal surface (or vice-versa) will result in half the pattern falling on a just painted surface at an angle that is not perfectly perpendicular and therefore a little farther away than "normal".
Another thing I read about not long ago was the recommendation to use a greater than normal overlap for HVLP, in addition to a closer gun-to-surface distance and a slower travel speed. More like 70% (?) than the standard 50% overlap. I have 50% engrained in my thinking and simply continue it with my spot HVLP with no noticeable problem although I do try to get a little closer and travel slower than I am otherwise used to.
My guess is when you go down from a 1.5 tip to a 1.3 tip you will decrease the paint flow rate, assuming the same paint viscosity. I don't think the pattern size will change automatically unless you choke down on the fan control knob. To keep the same application rate with the smaller tip and w/o changing the fan control, you might try slowing down your travel speed a little to see if that helps. You could also try cutting back a bit on the air pressure at the gun (say 5psi), especially with the smaller tip, since less paint per minute means less required air per minute to atomize. If you haven't already done so, you might want to check your atomization and pattern shape by rapidly triggering the gun on and off for just a fraction of a second on a piece of cardboard just to verify a smooth, uniform pattern that does not take on an hourglass shape. I can't think of anything else to suggest.
CNKS
07-27-2005 17:20:33
 Re: Question about Orange Peel in reply to Rod (NH), 07-27-2005 16:47:30
I think my gun is set up right, and I always do the cardboard thing, mainly to make sure one side of the air cap is not plugged. I haven't used the 1.3 much, certainly not on the last hood I did. I think the pattern is a little smaller, I need to compare when I start painting again. I have not heard about the 70% overlap, the person I corresponded with knows his stuff, and would have told me. Regardless of tip size, he recommends INCREASING the pressure 5 psi for better atomization, leaving the fluid alone, it is maxed out anyway--I have done that, but don't notice any difference. But, I may do what you say and decrease the air pressure, need to practice some first. As I say, on flat surfaces I don't have any problem. As to increasing it, the implication is that the 10 psi tip pressure is because of enviornmental regs, increasing the gun pressure slightly results in better atomization, if that (enviornmental) is not a concern. But, you are then beginning to defeat the purpose (less wasted paint) of HVLP. I have thought about starting in the middle of the hood, as you say, but I thought that might not be wise because you are not immediately doing the overlap on the other half of the 1st pass. In other words, I thought it would be too dry, but it doesn't take long to do a small hood. However, then I get two chances for the overspray, one on each side of the hood. The 460 hood I'm going to do next is long, I think it exceeds 4 feet. That one is going to be interesting. I'll keep your suggestions in mind --Thanks.
Rod (NH)
07-27-2005 19:18:20
 Re: Question about Orange Peel in reply to CNKS, 07-27-2005 17:20:33
Oh, I'll certainly agree that for better atomization, increasing the air pressure at the gun would be the correct way to go if needed. Even if you wind up exceeding the manufacturer's stated maximum 10 psig "at the cap" for HVLP. That is, unless you are in an area and a situation where legal compliance is the prime consideration. So far, with my somewhat limited experience with my HVLP spot gun, I have not found the need to either increase or decrease the gun air pressure from the stated maximum. However too high an air pressure for the paint flow can be a cause of dry spray - if, indeed, that is part of the problem.
I can't remember where I read the 70% and I am not even sure it was 70%. But it was greater than 50%. Here's what Dr. Gun at Sharp says:
"Here's a recap when spraying with HVLP
Depending on the brand of spray gun, you will see a wide range of inlet pressures to equal 10 PSI @ cap. Having enough CFM is critical. Spray at a closer distance. Use a faster stroke. Use a higher percentage of pattern overlap. On larger re-spray areas, never use faster than the medium temperature solvents; especially with high solids clears. Low noise doesn't mean slow gun speed. High solids, low VOC does not constitute high viscosity. Spray a balanced gun, i.e.: air to material ratio. The use of HVLP is just what the Doctor ordered. Don't buy it unless you can try it."
The recommendation to not use a fast reducer, apparently even if the temperature calls for it, is a new one for me. I haven't made any changes in reducer selection whether I use my HVLP spot or my non-HVLP full size. The MC161 HS clear that I use doesn't call for any reducer generally but does permit up to 10% retarder (again, if needed). I hadn't had a problem prior to the fender but I'll have to keep that tidbit in mind for a possible try the next time.
There shouldn't be a problem with matching up to and melting in with a pass that was done previously as long as the time is not too long. Think of doing a '60s full size Pontiac car hood in place - w/o touching the fenders with your midsection. You can't get all of it from one side. You have to do it halves from each side - unless you have those six foot long arms :o). That four foot long hood should not be a problem either. Plus it's probably narrow enough such that you can do the entire top and one side from one side if you choose. I just don't think it's the procedural things that are causing your problem - but I also don't know what might be.
CNKS
07-27-2005 20:05:13
 Re: Question about Orange Peel in reply to Rod (NH), 07-27-2005 19:18:20
I have a lot of small parts to experiment on, including one smaller piece that covers the gas tank, and has the same curvature as the hood, that I am willing to repeat a couple of times if I have to. Again, I think it is just technique. I'll figure it out. The hood is the only thing that may cause problems, gas tank is covered, but I'm going to paint it, grille is simple, other panels are flat, etc. I occasionally read Dr. Gun, never seen the reducer thing either, the rest of his statements are standard painting procedure. Except that he does recommend increasing pattern overlap. Like you, I don't know if I buy that one.
Rustyj14
08-18-2005 15:47:15
 Re: Question about Orange Peel in reply to CNKS, 07-27-2005 20:05:13
CNKS: Been reading your statements about orange peel. i began my auto body work experience in a shop that refinished cars and trucks. After gatting over the initial shock about how much i had to learn, things went along better. Later, i learned all about priming the bare metal and repaired areas, and sanding with wet-or-dry paper. I eventually got to paint with laquer finishes. The shop did baked enamel refinish jobs, with a gas fired oven. After a year or so of laquer painting, the regular painter got sick, so, being on a time limit for the car in the spray booth, the boss told me to go in and paint it. With synthetic enamel!! Uh, oh! And, to boot, it was a hi-metallic gold color! And, thats when i found out why the regular painter downed several hookers of rye whiskey and several beers, before starting to paint! Said it calmed his nerves! Well, shaky nerves have ruined many good refinish jobs! And, being too careful,or poor memory of where and how much paint you have already applied in certain areas, causes either runs or sags, or orange peel or flooded areas, which causes wrinkles, when the top coat dries before the lower coats! I learned a pattern for car painting that resulted in very good jobs. I gave the roof a single coat, then , starting at the front edge of the right front door,at the bottom, went all the way around the car to finish up where i started. Also, starting at the bottom of the doors and fenders and working up kept the paint from running, in case i had to refill the gun. Second time around was a double coat,including the roof, and also the final coat.It is advisable to avoid heavy coats at door joints, etc. I finally got to where i could duplicate factory finish on any or all parts! Very seldom did i get runs or sags, because i was in a closed booth and had no distractions! any one who had the temerity to open the spray booth door when the fan was running, got a face full of paint, pronto! So, it is all paying attention to the job at hand, getting practice before trying to paint yer car, truck, or tractor, paying attention to details, and now, having the correct breathing equipment for painting! Rustyj
