Paint Guns
Golfer
12-25-2004 08:54:47
What are the advantages and disadvantages of the H.V.L.P. gravity feed gun vs a Craftsman suction feed?
Butch(OH)
12-28-2004 13:59:44
 Re: Paint Guns in reply to Golfer, 12-25-2004 08:54:47
Most of the negatives I read about HVLPs read "I am going back to my conventional gun" CNKS brings up a good point. The techniques are different with the HVLPs and old pros with high pressure outfits have to learn them or throw the HVLPs in the trash bin. Like the others here my painting time is small compared to a pro body man but the only negatives I see are learning a new type gun. Since you too are fresh to painting you dont have that hurdle to overcome, you might as well learn a HVLP and enjoy the savings in materials. As for the brand of gun and price to pay I was told that about any gun will do a nice job for a job or two. The higher end equipment will last longer and you will be able to get parts down the road. Personaly I have never needed a part for a paint gun. My HVLP came from an autobody store and is made by Astro. It is all metal construction, cost was $175 and has painted 7 or so tractors. As far as I can tell it paints the same as new.
CNKS
12-26-2004 09:06:37
HVLP guns have less air at the tip, but may require more air at the inlet -- thus you need to match the gun to your compressor. If you have never painted before, HVLP will probably be the way to go, and you will likely have more success with it, as Indydirtfarmer said. Painters used to conventional guns may not like HVLP because it requires a different technique, mainly it is slower--again if you haven't painted much, you won't notice that. In my opinion, and as Indy says, the paint goes on smoother, thus there is less chance of runs and sags. Another advantage, if you run out of paint, you don't get the spits and sputters that will ruin your paint job with a conventional gun. I am not an experienced painter, and don't paint often enough to become an expert at it. However, my experiences with the conventional guns several years ago were mostly disasters, because I didn't have a clue about how to paint. More recently with HVLP, I read everything I could find first, and have had good results.
Indydirtfarmer
12-26-2004 07:42:52
First off, let me tell you that I'm relatively new at the game of painting. I don't know all the facts, but I do know what works for an amature like me.
The HVLP guns use a lot less air pressure to shoot paint. That results in less overspray, hence less wasted paint, less paint FUMES in the air (causing less pollutants to be in the air)and with less air pressuer, you end up with less chance of orange peel on your paint surface.
HVLP guns waste less paint for a couple reasons. You have better control of your paint while spraying, and the gun is simpler, and easier to clean.
I just recently finished a couple paint jobs (John Deere MT and JD 2440) The MT was done witha cheap HVLP gun from Home Depot. That gun is now my "primer gun". I also bought a more expensive Sharpe gun. It sprays a better pattern, but the cheap-o gun didn't do a bad job at all....
I sprayed a couple trucks about 10 years ago with a Binks #7 siphon gun. The Binks #7 was about as good as it gets. My work looked very amaturish. The 2 tractors I just did look about as good as anyones paint work. Good shine, nice slick finish, and NO RUNS OR ORANGE PEEL! The only difference.....The guns. HVLP guns are easier to use in my opinion. John
golfer
12-26-2004 17:24:58
 Re: Paint Guns in reply to Indydirtfarmer, 12-26-2004 07:42:52
I am new to spray painting and i am in the process of restoring a Ford Jubilee.
I saw the HVLP gun at Home Depot and also looked at a Campbell-Hausfeld at Lowe"s.
I havent seen a Sharpe; which model do you recommend and where is a good place to purchase one?
Thanks,
Joe
Big Jim
12-26-2004 20:48:02
 Re: Paint Guns in reply to golfer, 12-26-2004 17:24:58
The Sharpe FineX 300 is an excellent budget gun.
Georgia Boy
12-26-2004 19:43:42
 spraygun source in reply to golfer, 12-26-2004 17:24:58
Spraygun Depot has all the better spray guns, parts and accessories for sale on the internet. Autobodystore.com has a great discussion forum about using sprayguns and paint problems. I just painted by Farmall A with a DiVilbiss Finishline HVLP spraygun and PPG Acrylic Urethane paint, it looks great!
