CLEANING ORIGINAL IMPLEMENT PAINT
JKC
10-24-2004 09:01:14
I recently purchased a circa 1950 pull-behind plow that has been stored inside all of its life when not in-use. It has some great original paint and painted-on (stencilled) part numbers in several places. I have absolutely NO intention of stripping this item down and repainting it, as I feel the original paint is so much more desireable. I would, however, like to clean the age, dirt and dullness off of the paint. I am wondering if a mile soap and water, gently washed onto the original paint will do it any harm. I do not want to damage or wash the paint off in any way. Or, is there some other method anyone would recommend? Thanks.
Frank Stalfire
10-24-2004 12:45:10
 Re: CLEANING ORIGINAL IMPLEMENT PAINT in reply to JKC, 10-24-2004 09:01:14
Soap and water is a definate 1st step I would follow that with wax and grease remover, Dupont 3901 or RM 901, I don't know PPG number. always check on a n inconspicous area, you will need both as a solvent will not remove organic residue like dirt, menaure, and the solvent based cleaner will remove the grease but is not agressive enough to remove paint
tommyw
11-03-2004 07:50:26
 Re: CLEANING ORIGINAL IMPLEMENT PAINT in reply to Frank Stalfire, 10-24-2004 12:45:10
clean it gently with grey scotch brite ,then spray automotive clear over that, it will save the factory paint and look good for a long time.
moseed
11-23-2004 06:12:04
 Re: CLEANING ORIGINAL IMPLEMENT PAINT in reply to tommyw, 11-03-2004 07:50:26
Go to the Hit & Miss engine sites for your cure. Many there want to preserve the "original work clothes" of the engines. I can"t recall the exact mix but after gentle cleaning they rub a mixture of mineral spirits and linseed oil "I think" on the engines. Check their sites and confirm because I am on memory here and that is a failing resource the older I get. The engines, when finshed that way, look absolutley beautiful.
Good luck!
