sand blasting
chrisz
07-22-2004 13:13:27
Hi
I just recently purchased a ten gallon tank blaster. Up to 25 cfm at 145 psi. How good of a job will this do for me? What is the best media to use for tin work or large iron pieces. I am restoring many case tractors and a case combine. There are so many grits of sand glass etc.. to use what will be the best? Can I catch strain and re use. Any help from you guys would be great. Thanks much.
DL
07-25-2004 19:14:06
 Re: sand blasting in reply to chrisz, 07-22-2004 13:13:27
I've recently gotten in to blasting as well... I've been using a product similar to black beauty but instead of coal slag (black beauty), I've been using a copper slag... the two products look nearly identical, but there is a difference. The copper slag is a bit more aggressive... both do a great job! If memory serves, I think the "grit" is referred to as "30/60". You can definitely reclaim the abrasive... just be sure to sift it before re-use. The 10 gal/25 cfm will be a bit slow, but will get the job done. I started with a siphon blaster & 27.5 cfm compressor... got impatient and bought a 650# pot & 175 cfm compressor... now we're blastin'!!! Have fun with your resto's!
Regards, DL
Farmall Nut
07-23-2004 20:44:32
Just bought a blaster myself so I know where you are. I went to my local concrete block dealer and bought Black Beauty media. Get the FINE grade. I originally bought Medium but found that it would plug my 3.5 tip. I bought 3 bags of the stuff so instead of lugging 300 lbs of blasting media again, I bought a larger tip for my blasting gun. I found that the medium flowed freely thru a 5mm tip however it takes LOTS of air. Fortunately I have plenty of compressor volume and can pretty much blast continuously but if you have a smaller compressor I would suggest the 3.5mm tip and fine media. Oh btw, be prepared to prime the parts as soon as you blast or they will rust.
Jim
07-29-2004 17:41:10
 Re: Re: sand blasting in reply to Farmall Nut, 07-23-2004 20:44:32
About the priming. Do you clean the metal with anything right before priming? If so, what do you use?
