tractor holder, carrier
old bones
01-02-2004 19:26:40
i'm about ready to start the process of stripping down and repainting my 49 A. i don't have a dedicated paint room so will have to do it in my shop. problem is i can't leave it in there (at least in the same place) for the 4 to 5 weeks that i estimate it will take. i want to take the tires/wheels off before i get too far with it, so i need a wheeled dolly of some kind to hold to it up at the rear axles and front spindle so i can move it around and even out of the shop if need be. it will need to roll across gravel if i take it out of the shop. if anybody has done something like this, i'd sure appreciate knowing what to build. thanks in advance.
JMS/MN
01-03-2004 08:20:09
 Re: tractor holder, carrier in reply to old bones, 01-02-2004 19:26:40
I made a dolly using box beam from an old rear mount cultivator. It's either 5x7 or 6x8. Weld into a T, with pipe uprights on the outer ends to hold the rear axle, and a hinged upright on the long end of the T to hold the front end. Use 6-8 inch casters. The hinge lets you roll the frame underneath the tractor from the rear. Lower the tractor on to it, take the wheels off- saves space. Had a '37 B sitting on that dolly for years now- some AC restorations got ahead of it. Some day.....
