Removing loose paint from Alum Tucker Sno-Cat
Willy-N
10-22-2002 16:48:44
third party image
I have this 1952 Tucker Sno-Cat I want to paint. It is made out of aluminum sheet metal on the body. When I presure wash it some peals off right down to bare metal. So I need to remove the rest of it befor painting. What would work to remove it? What kind of paint would work on the metal that comes in a can? This is not for show but I want it to look better and be a solid color. Is there anything I should do to the metal befor painting after I remove the old paint? If I use a striper will it ruin the gasket seals on the windows? If so I need to use something else instead. Thanks Mark H.
Chester
10-22-2002 19:24:57
 Re: Removing loose paint from Alum Tucker Sno-Cat in reply to Willy-N, 10-22-2002 16:48:44
High presure washing, with hot water is what I have used in the past with pretty good results.
Have stripped off peeling paint from a couple of Dodge van roofs using that method.
That is an unusual machine, what do you use it for? Is it by chance Chrysler under that sheet metal?
Willy-N
10-22-2002 19:49:34
 Re: Re: Removing loose paint from Alum Tucker Sno-Cat in reply to Chester, 10-22-2002 19:24:57
It is used to go up mountians in the snow. Also like the ones used in Antartica and Ski Resorts to drag groomers for the runs or a trailer on Skis. It is powered by a Dodge Flat head 6 rated @ 95 hp with a 4 speed manual transmission in it. The power steering tracks articulate for turning and can tilt independently. It dose use Dodge/Chrysler truck running gear and transfer case modified to the tracks by different axle ends to big sprokets for the tracks. I guess you could say it is 4/track drive!! Mark H.
