painting help
Fred Kunkel
10-18-2007 19:11:29
Well I have started my restoring process. I have started out with small pieces just the light bar. I put on some primer tonight well I can see a big difference between were there was still paint there and not. What should I do?
CNKS
10-19-2007 09:51:39
 Re: painting help in reply to Fred Kunkel, 10-18-2007 19:11:29
If you don't remove all the paint you need to sand smooth or "feather" the edge of the old paint, otherwise what you see will be visible under everything you use including the topcoat. You need another coat of primer, also. Done correctly, the primer will cover everything.
circus
10-19-2007 06:15:13
Refinish steps that you probably wouldn't follow anyway. Clean. Clean again. Dismantle to the point that all refinish areas are accessible. Remove or protect anything that sandblasting will destroy like glass, radiator, plastic, seals etc. then PLUG ALL HOLES to keep sand out of the works. Sandblast everything being cautious (warpage) with the sheet metal. On the same day epoxy prime everything except sheet metal. Sheet metal should be DA sanded, do any needed body work, epoxy prime, primer surfacer, guide coat, fine DA sand until the guide coat is removed. Paint with aryl urethane or better within the time window stated for the epoxy. Assemble, detail, apply decals and inspect wiring, filters etc. A gigabit is needed to cover everything that can go wrong. Expect to purchase a $80 gallon of uri surfacer when a pint is needed and $60 sandpaper when $5 is needed.
