TSC paint any good and how to use it on a working tractor?
Ken in PA
05-09-2002 17:26:09
I have the motor out of my tractor now and I thought while everything is apart it may be a good time to repaint the whole thing when I bolt the engine back in.
I see that TSC has tractor enamel on sale and I wondered if it was any good? I think I would be using a hardener in it as I never seem to get paint to dry for me.
Next question. This isn't a restoration here so I am not going to spend the time to take everyting down to bare metal and do all the fancy things needed for a parade quality job..On the other hand, if I am going to buy materials and take the time to spray it, I don't want it coming off with a hard rain so what would be the best approach and what prep products should I use?
I plan to strip the tractor of the bolt on stuff and just do the rearend,tranny, and motor all at one time and I will scrub everything real good and clean,wire brush any loose areas, and scuff it all down with a scotchbrite type pad.
What should I do at this point before I spray the enamel?
Just for some backround info. I haven't touched a spray gun for 20yrs and that was the only time I ever did. This doesn't need to be a show quality job but I sure want it better than a brush and roller job! I guess my main worry is good adhesion and dry time and any good tips for a quick way to prep it.
I really don't think I want to spend more than 1/2 a day getting it ready for primer if that helps.
Thanks for any ideas!
Ken
tractor is an 8N that will be red/gray but the gray will be done later.
